Computer Aided Design
If..else.. inside IMOS12.0
11/24/16
Lian Member
Good Day. I am Lian and using IMOS 12.0 for months now.
i was wondering if is it possible to have an "IF...ELSE" case statement inside the Element Manager?
because i have a cabinet in which its hinge power factor will differ depending on the (a)door weight and (b)width. rather than making every width of the cabinet and every door type, is there a way to shortcut the process? it will just take so much time to edit every single one.
applying it in $Variables will still have user intervention. and if the user doesn't have the knowledge about the need to change the hinge, then it might cause more problems.
that's why i thought of making an "If...else.." command but i don't know how to state the command. is there a way in which imos will recognize the cabinet size and automatically sets the proper hinge mechanism that the door need?
11/25/16       #2: If..else.. inside IMOS12.0 ...
Dan
I haven't seen it done with an if..and..else.. type of statement but if we're referring to something like piston choice on a flap or lift it is fairly easy to do using the characteristics in the connection situation and limiting the available choices based on materials, thickness, size and so on. You can also add filters to zero in on the product you want the system to choose. This will eliminate all of the choices that do not meet or have all of the characteristics defined.
11/25/16       #3: If..else.. inside IMOS12.0 ...
Lian Member
Thanks Dan.
Yes, i have tried limiting the Characteristics section, though this doorsize-powerfactor case seem too situational. I settled in making every single cabinet for now, hoping a solution would arise.
11/28/16       #4: If..else.. inside IMOS12.0 ...
Chris B
Dan is right the best way would be with connection situation you can set up the connection situation by door weight and size for each hardware.
