Computer Aided Design
Cabnetware question
3/29/17
Joe Member
I am running Cabnetware 8.0 Frame version.
to change user info in preferences I used to go to help
about Cabnetware
touch on the icon in the upper left hand corner and
notepad would open
a little ways down under user info
line 1---you could change company name.
Now I try that and I hit save and it wont save the changes.
Am I missing something???Help :-(
3/30/17       #2: Cabnetware question ...
Jim Diebolt Member
Website: http://forum.designsbydiebolt.com/
That should work. I just did the same on my V-14 and it still works for me. Remember that when you do this it will only stay there until the program is closed and then it will revert back to the original. Only having your key re burned will change it for ever.
On another note, if you are going to keep using Cabnetware going forward I would highly recommend updating to V-14 before they stop supporting the software at the end of April. It will only cost $500.00 to update no matter how far back you are in versions of CW. If you want to see what is new in each version update (V-9 through V-14) just contact me and I can send you links from my tech forum explaining each update. After April 30th you will not have any option to do this.
Please checkout the link to my new Cabnetware Tech Forum below to see what I have to offer.
3/30/17       #3: Cabnetware question ...
Joe Member
Jim, Sounds good, You can send links to
joecabinetry@yahoo.com
Now I only use detailer frame and euro version. is V14 the latest build? I am using build 8. something.
I noticed you are restarting your website. If I purchase the V14 would you be able to walk me through any issues? Is there problems with that build that are insurmountable?
Thanks, Joseph
PS Where do you hale from?
3/30/17       #4: Cabnetware question ...
Jim Diebolt Member
Version 14 is light years beyond Version 8. If you read each link that I will send you it will show you all the new features in each yearly program update. A few years back Vero rebuilt the software to stop almost all the crashing and it is very stable now.
I have opened a new tech forum that has a yearly membership required. After April 30th this year Planit/Vero will no longer support the Cabnetware line so that is why I have started a new forum.
If you join my forum you can get the help you would need for setting up V-14 by just posting your questions for me or others to answer.
I now live in Northern California in a small historic gold mining town called Placerville. We retired in early 2013 and moved away from the big city.
3/30/17       #5: Cabnetware question ...
Joe Member
That's great I look forward to reading the info from the links!
I was raised in Williams ca. 60 miles north of Sacramento right on I 5
3/30/17       #6: Cabnetware question ...
Jim Diebolt Member
The link has been sent to you. Contact me with any questions.
6/30/18       #7: Cabnetware question ...
Michael Murphy Member
The name comes from what is programmed onto the key, unless you have the old style Cabnetware Key instead of the Planit style key. In the program, go to File-Utilities and if it says on that menu "Key Information", you have the old CW key. If it says "Authorization Codes" it's a Planit key.
Planit keys enter the name that is "burned" onto the key.
Feel free to email me with any questions you might have about CW
1/18/20       #8: Cabnetware question ...
Jim Diebolt  Member
Website: http://forum.designsbydiebolt.com/viewforum.php?f=...
I now have a program that will change the default name that is burned on your security key. If you want information about that just checkout the link below.
Change your default name on your key
    • ECabinet Systems
    • INNERGY
    • Cabinet Pro
