Computer Aided Design
Cabinet Vision question
5/22/17
Good morning All
I have a client with CV8 and they want to send me dxf files. How can this be done?
I'm hoping for a folder with all the files individually, not nested.
Thanks in advance.
7/26/17       #2: Cabinet Vision question ...
vertice Member
yes. but to import the the dxf files they have to be properly prepared for import and that depends if you want to import direct into s2m for output or into the edit tab to just shape your part around the outline. to out put to s2m the dxf has to have the code written into the drawing(their part) and has to match your s2m dxf import naming convention amongst other preparations on your part. If you've never done dxf import into s2m it will take you many trial and errors to get it right. to import into edit tab and shape around outline it just has to be scaled correctly.
