Computer Aided Design
AlphaCam 3D Programming
11/7/17
TDD
I have a job where I need to build pyramid raised panels for a furniture piece (See picture in link below). I have AlphaCam Standard Router 2017, and have done lots of profiling, but not a lot of 3D work. I have talked to AlphaCam about taking a class, but the soonest they can get me in is early December.
Is there anyone who could give me a quick tutorial on how to do this? I have been using AlphaCam for many years, so I don't think it will take long for me to get it, I just need a little boost in the right direction.
http://www.woodlandfurniture.com/tearpiece/pagano-cabinet
11/8/17       #3: AlphaCam 3D Programming ...
Wood Dust
TDD
I would be able to help you with this. We can setup a team viewer meeting to help get these done . Feel free to call or text me. 860.309.5177 . I am in CT
11/9/17       #4: AlphaCam 3D Programming ...
TDD,
You might be able to pull it off, but you may have trouble with the Standard Module of Alphacam. Last time I saw a Standard version, it could not make workplanes, or do any solid or surface machining. I am guessing at a minimum you would need the Advanced version to get that done with a adjustable angle aggregate or a ball end. Over the past few releases, Alphacam has been increasing capabilities of the lower end versions. Hopefully you can get it done. Good luck.
12/19/17       #5: AlphaCam 3D Programming ...
wilIiam Member
i had an old version of ac that we did a little carving with. we started with an stl file generated in rhino then imported it into ac. then there was a group of drop down commands where you would create a material like a 3d block roughly the size of your stl model then you would align the created material and stl model and select another command from the same group to create an automatic tool path.there was a list of questions to answer like where to start and how close to overlap passes. its been awhile and i dont remember the command names but they were all grouped together in a drop down. it was a fairly automatic process as you would execute alll the commands from the list in sequential order. hope this helps.
