Computer Aided Design
2D CURVED LOOK IN ELEVATIONS
2/21/18
steve ayars Member
Just wondering if anyone has a good way to make a 2d front elevation look like it is curving/radiused. I'm working on a radiused settee and need something for a presentation. thank you
2/21/18       #2: 2D CURVED LOOK IN ELEVATIONS ...
James Falk
Website: http://www.progressivewoodworks.com
Greetings Steve,
You could try something like this. Draw your original curve, copy it lower elevation, draw the vertical lines in and then trim all of the lines away that do not belong. It is not exact, but it may be close enough.
All the best,
James
View higher quality, full size image (1176 X 679)
2/21/18       #3: 2D CURVED LOOK IN ELEVATIONS ...
MarkB Member
Why not just give a normal 2D elevation (the curve would be represented by an ever tightening pattern/profile spacing out towards the edges) with the plan view directly above OR insert a 3D perspective somewhere in the sheet?
2/23/18       #4: 2D CURVED LOOK IN ELEVATIONS ...
Mark R Member
If you're using AutoCAD you can apply a gradient hatch for a shaded effect.
GradientHatch.pdf
2/26/18       #5: 2D CURVED LOOK IN ELEVATIONS ...
Brian
Why not draw it in 3D then use FLATSHOT and the section commands to get your 2D representations. If you're doing a presentation you really need or at least I would feel that I would need to be in 3D to make it look realistic.
6/8/18       #6: 2D CURVED LOOK IN ELEVATIONS ...
Donald Caron  Member
Website: http://www.highcamengineering.com
Hi Steve,
I use a reference concave/convex arc place convieniently on the elevation, then use a very light gradient of vertical lines trimmed to the reference line; I then erase the reference line leaving a shadow trace of the curved surface plane. My gradient is a dynamic block stretched from "A" to "B".
I hope this makes sense, its classical form, Chippendale used it.
