Computer Aided Design
Need help with tool side roughing for hogging operation in Alphacam
3/15/18
Ian
I am trying to use a 40 mm hogging tool to rough out material on a profile. I would like to use the tool side, cutting parrallel to the top face of a solid model , then I would like to go on and use a second and third operation to clean up the profile. Any information in the Alphacam training PDF's pretty much refers to using a ball end or straight end mill, mostly machining with the tool tip. Any advice would be greatly appreciated.
4/9/18       #2: Need help with tool side roughing f ...
Marek
Website: http://www.cadcam-softcz.cz
Hello,
if i understand correct what you want. For this does not exist automatic cycle. But you can create spline/polyline machining and offset it for a roughing tool. If you have project in Alphacam, you can upload it there or send me on msskotak@gmail.com
