Computer Aided Design
Solid 2012 R1
4/11/18
dustmaker1
I am currently using Solid Standard 2012 R1. Last version owner upgraded to. Just installed this on a new computer and having trouble with wall connections. on earlier versions when walls are connected I could grab a wall and all other walls would move with it. In this version when I try to move a wall it automatically disconnects from other walls and only items associated with that wall will move with it.
I am thinking there must be a setting to change this but can not find it.
What would be the point of connecting walls if they did not stay that way.
Thanks in advance.
Paul R
4/11/18       #2: Solid 2012 R1 ...
Dave
Select the end of the wall you want to resize before typing your new size
If you want to move several walls, do a crossing window over them & move by the small cross when you hover over a snap point....
4/12/18       #3: Solid 2012 R1 ...
dustmaker1 Member
Thank you Dave, I guess I need to click on each wall, even though they do not stay highlighted, and then draw box around them to move together. Not sure this is better than the old way of just disconnecting wall at a point you want and all others move together, but it is what it is.
Paul R
4/12/18       #4: Solid 2012 R1 ...
Chevy
Ahh,,2012r2 ,,,one of the best versions ,,,when the blind dado package was available for this version,,,revolutionized the Cnc world.
Just thinking aloud
-Chev
5/22/18       #5: Solid 2012 R1 ...
Cactus
Hello Chevy can you please help with a post processor.
5/22/18       #6: Solid 2012 R1 ...
Chevy
just got message,,,,,will post some same nc code in a few,,,,,,
