Computer Aided Design
Drawing Compound radius moulding
6/21/18
Has anyone been able to correctly draw and arched casing for an opening in a curved room in plane Jane Autocad? I was able to draw the inside path of the moulding and project that onto the surface of the radial wall, but when I sweep the moulding to get a 3d solid, the 2d moulding profile does not twist properly in order to stay flat to the wall throughout the 3d path. I was able to get a proper model years ago using Inventor, but I don't have that anymore. Thanks for any insight.
6/21/18       #2: Drawing Compound radius moulding ...
Jared
I'm 96.8% sure you can do that by extruding along a path instead of the sweep command.
6/22/18       #3: Drawing Compound radius moulding ...
Thanks for the reply. Did not exactly get the correct profile throughout the extrusion. I had tried that too. loft gets me a little closer, but still not quite right. I am stumped.
6/22/18       #4: Drawing Compound radius moulding ...
SG
In Rhino I would use a Sweep2 command, which allows selection of two rails - I don't use ACAD, so don't know if that command exists. Rhino has the same issues you describe using either loft or extruding (or Sweep1) for that purpose. The Sweep2 does it correctly, however - just did that yesterday drawing circular handrail.
6/25/18       #5: Drawing Compound radius moulding ...
Mark R Member
Loft will do it if profiles (cross-sections) are positioned carefully and evenly distributed ... at least 5.
6/26/18       #6: Drawing Compound radius moulding ...
Yes, It looks to me like 5 sections through a 180° arc gets me close enough. Most curved walls will be out of tolerance anyway unless constructed in the shop with CNC machined plates. Thanks all.
