Computer Aided Design
Batch Rotating DXF files
6/21/18
Richard
Hello All,
Does anyone know if there's a way that I can automate the process of opening a number of DXF files, rotating them 90° and re saving them?
Richard
6/26/18       #2: Batch Rotating DXF files ...
Gary Balcom
Richard,
Do you have any experience with Lisp routines? Someone in the know could make that work I'd bet.
Here is a link to put you down that path:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/batch-process-all-
drawings-in-folder/td-p/2539171
6/28/18       #3: Batch Rotating DXF files ...
Richard
Thanks Gary.
I had a look at the link you posted. Does look like Lisp would be the way to go. However I have zero experience with this & looks like it would be beyond me at this time and unfortunately I don't have the time to spend on learning this right now.
Do you know of anyone who maybe willing to assist with this? Or where I could look for someone?
Thank you
Richard
6/30/18       #4: Batch Rotating DXF files ...
david wishengrad
Message me and I will see if I can help.
7/2/18       #5: Batch Rotating DXF files ...
david wishengrad
If you have not installed the ACAD vba enabler, do it.
Then open the VBA IDE and in the acad project window, choose "thisdrawing" and add the code below.
Make a folder on your C: drive called dxf.
Put a copy of your dxf's in that folder.
This will import each, rotate whatever is in there and save it as a dwg in the same folder.
With some drawing that doesn't matter already open, click somewhere in the RotateDXF sub and press the F5 key.
Public Sub RotateDXF()
Dim newdoc As AcadDocument
Dim importFile As String
Dim InsertPoint(0 To 2) As Double
Dim scalefactor As Double
Dim DXF_File As String
Dim path As String
Dim SlashPos As Integer
Dim FileCountx As Integer
Dim FilesArray() As String
Dim tmpFilename As String
path = "C:\DXF\"
FilesArray = GetFiles(path)
FileCountx = -1
teststring1 = ThisDrawing.Name
For FileCountx = LBound(FilesArray) To UBound(FilesArray)
importFile = LCase(path & FilesArray(FileCountx))
tmpFilename = importFile
Inpos = InStrRev(tmpFilename, ".")
If Inpos > 0 Then
tmpFilename = Mid(tmpFilename, Inpos + 1)
Else
tmpFilename = tmpFilename
End If
If tmpFilename = LCase("dxf") Then
Set newdoc = Application.Documents.Add("acad.dwt")
InsertPoint(0) = 0#
InsertPoint(1) = 0#
InsertPoint(2) = 0#
scalefactor = 1#
newdoc.Import importFile, InsertPoint, scalefactor
ZoomAll
newdoc.SendCommand "rotate" & vbCr & "all" & vbCr & vbCr & "0,0,0" & vbCr & "90" & vbCr
ZoomAll
DXF_File = Left$(importFile, InStrRev(importFile, ".") - 1) & ".dwg"
'newdoc.SaveAs DXF_File, acR15_dxf
newdoc.SaveAs DXF_File, acR15_dwg
newdoc.Close
Else
'do nothing
End If
Next
End Sub
Function GetFiles(ByVal FullPath As String) As String()
Dim num_files As Integer
Dim file_name As String
num_files = -1
If Right(FullPath, 1) "\" Then FullPath = FullPath & "\"
FullPath = FullPath & "*.*"
file_name = Dir(FullPath, vbNormal)
Do While Len(file_name) > 0
If FileName "." And FileName ".." Then
num_files = num_files + 1
ReDim Preserve FilesArray(0 To num_files)
FilesArray(num_files) = file_name
End If
file_name = Dir$()
Loop
GetFiles = FilesArray
End Function
7/3/18       #6: Batch Rotating DXF files ...
david wishengrad
If they need to be saved as a dxf, then it must be exported. ACAD does not open dxf's or save them directly. They must be imported and exported. My code above uses the important method, but does not export. This sample code below provides an example of how to use export.
Sub Ch3_ImportingAndExporting()
' Create the circle for visual representation
Dim circleObj As AcadCircle
Dim centerPt(0 To 2) As Double
Dim radius As Double
centerPt(0) = 2: centerPt(1) = 2: centerPt(2) = 0
radius = 1
Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius)
ThisDrawing.Application.ZoomAll
' Create an empty selection set
Dim sset As AcadSelectionSet
Set sset = ThisDrawing.SelectionSets.Add("NEWSSET")
' Export the current drawing to a DXF file in the
' AutoCAD temporary file directory
Dim tempPath As String
Dim exportFile As String
Const dxfname As String = "DXFExprt"
tempPath = ThisDrawing.Application.preferences.Files.TempFilePath
exportFile = tempPath & dxfname
ThisDrawing.Export exportFile, "DXF", sset
' Delete the empty selection set
ThisDrawing.SelectionSets.Item("NEWSSET").Delete
' Open a new drawing
ThisDrawing.Application.Documents.Add "acad.dwt"
' Define the import
Dim insertPoint(0 To 2) As Double
importFile = tempPath & dxfname & ".dxf"
insertPoint(0) = 0: insertPoint(1) = 0: insertPoint(2) = 0
scalefactor = 2#
' Import the file
ThisDrawing.Import importFile, insertPoint, scalefactor
End Sub
7/7/18       #7: Batch Rotating DXF files ...
david wishengrad
Any luck?
7/7/18       #8: Batch Rotating DXF files ...
Richard
Thanks David,
I have not had a chance to test this yet. I will let you know how it goes.
Thank you
