Computer Aided Design
Change cut direction on a polyline in Alphacam.
7/25/18
Ian
Hi, I am trying to write a horizntal cutting program to machine a radius from a corner that was originally cut vertically. I have drawn a polyline in the cornerand machine along it, but when I go to the opposing side to make the same cut, simulation shows it wanting to cut through the part on the way to the next part of the operation. The machine has a 200 mm safety set in it, but I don't want to rely on that. After turning on ghost tools, I see that both arrows point down, I am thinking that if I can get one to point up and one to point down, I can start on the up side and avoid fouling. Trying to change direction in tool directions doesn't work, even deleting the polylines and re drawing them and trying to assign direction does not work.
7/27/18       #2: Change cut direction on a polyline ...
email your .ard or upload it here, I'll take a look at what you are doing.
7/30/18       #3: Change cut direction on a polyline ...
Ian,
Did not hear anything from you, so I assumed you figured out that tool side is assigned while applying the tool path to a 3d polyline. However, it is generally easier to draw and cut 2d geometry on a workplane. Either way, glad you figured it out.
7/30/18       #4: Change cut direction on a polyline ...
Ian
was just about to post the file, but that sounds like an easy solution, thank you I'll try it
7/31/18       #5: Change cut direction on a polyline ...
Ian
Well, I kind of got it to work, but machining vertically, I can not get my lead in/ out to behave without fouling. It looks ok in simulation, but fouls on the machine. Is there a way to manipulate the leads to avoid this?
8/1/18       #6: Change cut direction on a polyline ...
MIke
Email or post it up here. There are ways to manipulate the ins/outs, but it all comes down geometry that you are cutting and where the tool is when you finish.
8/1/18       #7: Change cut direction on a polyline ...
Ian Member
Forum will not let me upload an ARD file
8/1/18       #8: Change cut direction on a polyline ...
Ian,
You should be able to click on my name and send me an email message. When I respond, you can attach the drawing. Not sure why it won't let you attach it though.
