Computer Aided Design
WoodCad Cam/imos Help
9/21/18
Marcin Miruta
I am hoping there is someone out there that has a strong familiarity with WCC 12.0. I Am currently trying to find a way that allows me to have chamfers on items that start at a set point and end at a set point. IE Door Stiles that have a chamfer that begins 3" in from top and end 3" from the bottom. I have no problem having a chamfer run straight through, but thats not what I require.
Thank You for your time.
9/22/18       #3: WoodCad Cam/imos Help ...
dedmin
Use Outside Contour to split the edge.
9/24/18       #4: WoodCad Cam/imos Help ...
Marcin Miruta
alright ill give that a try, thanks.
9/24/18       #5: WoodCad Cam/imos Help ...
Marcin Miruta
yeah im not too familiar with the split edge function. I've attached a picture of what im trying to do. The highlighted line is the edge im attempting to split. Its a single filler item for refrence.
View higher quality, full size image (960 X 540)
