Computer Aided Design
3d Autocad tips
11/2/18
4hardwood Member
Hi all,
I currently do all my drawing in 2d with autocad. I get a lot of requests to see things in 3d. I would like to transition to 3d. I have no problems learning the commands. But the thing I struggle the most with is proper workflow. For example, in 2d I always start with the floor plan then from there I use construction lines to do all my elevations from the plan view. Then I do all my section cuts from the elevation with construction lines. Things are pretty strait forward. I know with time and discipline things will come together but just thought i'd ask to see how others do things in 3d specific to cabinetry. From start to finish. Mabye, if your willing, share how you manage your layers. It seems that you need more than what i'm use to in 2d.
Any tips I would be glad to receive. By the way I do use bricscad not autocad. But it is virtually the same thing in almost everything. We are a small shop and can not justify Microvellum.
We do high end residential with a lot of custom built-ins.
11/3/18       #2: 3d Autocad tips ...
CADMebel
BricsCAD is excellent and more cost effective! First use this videos to familiarize with BricsCAD - https://www.youtube.com/user/bricsys/playlists?shelf_id=8&sort=dd&view=50
Start thinking like in the shop - You use boards, panels and hardware to build furniture - do the same in 3D, then use this to make sections, elevations and views - https://www.youtube.com/watch?v=COkW63wpheM&index=14&list=PLONdQc9bizscUIX
eFtH93AsV1RO6Q7wtZ
11/5/18       #3: 3d Autocad tips ...
4hardwood Member
Thanks for the links. I checked them out and found them to be helpful.
I choose bricscad because of the added features that autocad does not have like 3d constraints. It won't be a while until I mess around with them but hope to create a library of cabinets that I can insert into my drawings. It seems that brycsys is much more ambitious to improve the platform and adding new features in the future than Autocad.
12/17/18       #4: 3d Autocad tips ...
Bill Walker  Member
Great Advice from CADMebel, IMHO...
I resisted drawing in 3d, myself, until I realized that THEN, I was doing what I would've done out in the shop...Draw your plan views in "World View" i.e. looking "down" on the Plan View...THEN, start your model, using the 3D views, building "up" from " Z=0 "...All your solids will now relate to, and be anchored by, where your plan-view places them, and you have a "check" on your work at all times...
