Computer Aided Design
AlphaCAM nesting
11/5/18
Hi All.
Is there a way to nest onto 5X10 sheets but treat them as 2 5X5 sheets - parts not crossing the split line.
I have tried setting up a clamp as the line on a 5X10 sheet but that only works on the first sheet.
Any ideas?
11/8/18       #3: AlphaCAM nesting ...
Zak
there is a function that allows you to define an area of the sheet that you don't want to nest into. It's called, Define Sheets and No-Nest Zones.
Just draw I very narrow rectangle (.005" wide) that spans the sheet from front to back, and define that rectangle as the no nest zone.
11/8/18       #4: AlphaCAM nesting ...
Awesome
Thanks.
11/29/18       #5: AlphaCAM nesting ...
DONALD WHATLEY  Member
If you have more issues give me a call I may be able to walk you though it 424-652-0563
Donald
