Computer Aided Design
Cabinet Design Times
6/9/19
Matt Stout Member
Hey guys,
I'm looking for some input from cabinet designers.
What would you say your completion time is from when you receive a cabinet design, draw it in whatever software you use then ship it out to the shop?
We currently use Sketchup with CabinetSense and then I have to manually create all the dimensions our guys need for the shop in Sketchup Layout. It takes too long.
Any suggestions on software and standard turn around times from design to production?
6/9/19       #2: Cabinet Design Times ...
Depends on the job obviously, but a smaller kitchen I can have it drawn, shop prints made, cut lists made, and programs for the router made in a couple of hours. It never works that way since I'm never drawing it live with the client there. I don't think I've ever built a job off version one.
Our machining is a little odd and unless the cabinet used is unchanged from what is in the library there's always some tweaks to the machining that take time.
6/9/19       #3: Cabinet Design Times ...
Pretty much the same scenario as Karl in that it varies greatly especially on highly customized jobs. But for a basic job if there is nothing or only one or two totally custom elements where Im just dragging straight in from the library I can usually have everything out including g-code, cutlists, and BOM in half an our or so. Unfortunately we dont get a ton of work like that and usually have a lot of custom elements across many cabs.
Im running the same software and dont seem to have the issues with dimensioning you mention. Are you running scene management and using scenes? Setting up some different templates in SU for certain types of jobs can help. Other than the very odd stuff we dont heavily dimension paperwork going out to the shop. CS builds a cutlist and door and drawer box lists that come out of excel and other than any odd drawer heights or the one-of elements its all fairly standard.
6/9/19       #4: Cabinet Design Times ...
Have you watched this? https://www.youtube.com/watch?v=ohRjHKJFIs4&t=173s
6/11/19       #5: Cabinet Design Times ...
Matt Stout Member
Thanks guys. Yeah I have done some one on one training with Paul. Real nice guy. I just need to find a way to increase my production time.
I finally was able to get the dimensions to work with what our shop crew wants. Saved a bit of time.
