Subject: Re: Pattern Systems/Biesse Rover
9/19/14
Jim Smith
Does anyone know if tech support is still available for Pattern Systems? I know they become a part of 20/20 but have heard that 20/20 has discontinued selling the products. I have even heard that 20/20 is now part of Styles Machinery.
What I really in need of is my company has just purchased a Biesse Rover, PTP and we are still using Pattern Systems. I am looking for some assistance with setting up the machine map including the barcode information that will print on the label. Is there anyone out there still using Pattern Systems and Biesse?
Thank You Very Much:
Jim Smith
Casework Technologies
9/21/14       #2: Pattern Systems/Biesse Rover ...
ozan
What is pattern systems ? You need to program each labels in biesse R.
9/22/14       #3: Pattern Systems/Biesse Rover ...
Jim Smith
Ozan:
What is Pattern Systems?
I didn’t think that they have fell that far. Or are you being funny? Pattern Systems used to be at the top of cabinet making software for drawing, cutlisting, optimization, machining, labels, ect. But as newer technology was developed and newer programs came out they never advanced so they fell by the wayside.
I am not sure what that means, are you saying I need to create each label by hand?
Within DrillMate (the part of Pattern Systems that creates the drilling/routing information) is a line in the Machine Map that creates the barcode and sends it to the label software. Currently it is set up with for program name. However the machine needs the program name followed by .bpp for the machine to pull up the program at the machine. So I need to find a way to add the .bpp to the label of find a way for Biesse to not require the .bpp at the end of the program name.
This is why I am hoping to find someone that is maybe still using Pattern Systems and A Biesse Rover.
Thank You
Jim Smith
9/22/14       #4: Pattern Systems/Biesse Rover ...
Dylan
Jim, morning, one correction,
you do not need to add the .bpp to the the program for it to read..your machine will import an ISO created program direct from PS or 3rd party Post Processor.
Not sure if the post is completed with PS but sure someone has it.
(please provide Model/year of your Rover)
For the label..it needs to be Code 39 and the program extension will be (.iso) or .txt. The path will be xnc (wnc)/home/p_p/prog and the scanner will default to look in that folder for the program. I can send you the doc to set up the scanner..(symbol ls4208 with 9pin connector and power supply)
As always, for more technical info. please contact service@biesseamerica.com or 704-357-3131.
Regards
dylan bayliss
www.machineconsult.com
9/22/14       #5: Pattern Systems/Biesse Rover ...
Jim Smith
Dylan
Thank you for your response, the machine is a 2014 Rover A_S1332, we have had it for less than a month and have just switched from an old Busellato.
We had 4 different machine maps or post for Biesse machines and prior to purchasing the machine had sent this information to Biesse to verify if it would work, they responded it would. We are now trying to work through different issues.
As far as adding the .bpp to the barcode this information was provided by Biesse tech support. The barcode I am using I believe is code 39 but will need to check, the other information you provided I will also need to check and see if I have this set correctly.
Please send the doc for the scanner setup, it may provide some information I don’t already have, thank you in advance. My e-mail is j-smith@c-tec.us and my system blocks out .doc as well as other extensions so it would work best if you send as a zip file, or rename with a different extension before sending and I will rename back.
Thank You
Jim Smith
9/23/14       #6: Pattern Systems/Biesse Rover ...
ozan
Jim,
Yes you should contact directly Biesse support, it may simple problem.
12/31/14       #7: Pattern Systems/Biesse Rover ...
jack
Unless you go with Biesse software you will need to use the WRT package within the the wrt software that runs the input and output addresses. As for patern systems I did an install around 2005 that used this software and it was an issue back then as customer could not do multi programs without inserting certain characters to allow it to optimize the code using cam 3. Ask about the converter Biesse Canada has to convert your standard iso code to run on the new Rover. Just so you know they do not push the converter as they would have you use Biesseworks to run machine.
