Subject: Re: cnc router spindle cooling
10/13/14
james amo Member
do all cnc router spindles require a ton
of compressed air to keep them cool or do
some cool by a fan. I am looking
at getting
a used router soon but dont want to get a bigger compressor too.
10/13/14       #2: cnc router spindle cooling ...
jerry Member
mine has a fan no need for air to cool but you will need it for counter balance and an ATC if you get one.
10/13/14       #3: cnc router spindle cooling ...
james amo Member
I think I would need to know what spindel
manufacturers use the venturi compressed air approach. I think columbo uses an
electric fan but not sure of the other makes
I was thinking of shop sabre brand or
andi or thermwood ? any response would
be app
10/14/14       #4: cnc router spindle cooling ...
cabinetmaker
We run our entire shop off a 10 hp compressor and make up to 20 tool changes on the cnc per hour easy. We spray glue, sand corian and spray lacquer, not to mention the edgebander is constantly running. We have an HSD spindle and Biesse router
10/14/14       #5: cnc router spindle cooling ...
ken
I run a shopsabre and just put a hsd atc on it. You will need air also for their balance cylinder for the spindle.
The only way I can see you not needing air is going to a manual tool change spindle. A moderate compressor of maybe 30 gallon or more should keep up fine. I have a stand up 5 hp compressor and it kicks off every 30 minutes or so. The dust collection and vac hold down are more costly and more noise than the compressor.
10/14/14       #6: cnc router spindle cooling ...
james amo Member
yes thank you I know I will air I am just
trying to avoid a spindle that cools
itself with compressed air. I have a HSD
spindle on my rover point to point and
that dosent use much air. Does anybody
know which spindles use compressed air to cool themselves?
11/9/14       #7: cnc router spindle cooling ...
Brian
We have liquid cooling on the anderson CabMaxx. It's the way to go when your in a production situation. Be careful of these smaller routers, some are very low production as in they won't make very many parts per hour.
