Subject: Re: Collet nuts
Collet nuts
1/26/15
Good evening All
I need some LH tooling for some work that I need to do. There is some information online that suggests that ball bearing collet nuts can be used instead of LH tool holders.
Anyone have any experience or comments?
1/27/15       #2: Collet nuts ...
I have done what you are suggesting without any problems, but only in a pinch. I usually have a LH holder in my inventory, but I have used a RH holder with a LH tool when desperate. The only reason I did that is I only take very light cuts and no sustained routing with my LH tools. Usually just to break edge banding, or to make a small cut on solids to avoid tear out. Just a note, I always tighten my collet nuts with a torque wrench. That way everyone that loads a tool has them tightened the same.
1/27/15       #3: Collet nuts ...
We use bearing collet nuts on LH tools every day. Never had a problem.
