Subject: Re: Programming an Arc
Programming an Arc
7/10/15
Jerry
I'm new to programming and having a little trouble figuring out how to program an arc cut out. I'm using Xilog Plus, but can input simple G codes as well. I've asked SCMI for help but haven't received a response in over a week from them.
The panel is 863.6 x 230 x 18 and an origin of J. The tangent points are at 50 and 175mm on Y, and the depth is 26mm on X.
Thank you for your help!
Jerry
7/10/15       #2: Programming an Arc ...
Mark T
The centerline code would be
G1 X863.6 Y50
G2 Y175. I925.72019 J112.5
This is EIA/ISO standard code, lower left corner of the panel as X & Y zero.
I typically do not work on SCMI so unsure if it will work within their syntax.
Mark T.
7/13/15       #3: Programming an Arc ...
Jerry
Thank you for your help Mark!
Jerry
