Subject: Re: In need of the .AC File Format for the G57 Panel Saw
6/1/16
Frank D. Jimenez  Member
Website: http://www.cabinetpro.com
One of our customers has a G57 Panel Saw from Giben. For almost a year now we have been trying to get the file format for the required .AC file in order for Cabinet Pro software to automatically write to it for our customer. This is not a difficult process. We can implement just about ANY post into Cabinet Pro in a few days, as long as we know what file format to use. The problem is that everytime we speak to someone at Giben's technical support, we get a different answer, or get a file format for machines that are no longer being made! Three months ago, our customer finally received the "correct" file format and sent it to us. I implemented it within Cabinet Pro in a few days and sent it back to Giben for a final check. The answer was that the file format was a different machine than what the customer had! The customer and I were both irritated and so we had a very serious 3-way conversation with Giben's tech support. He promised to have the correct file format in both of our email boxes within 24 hours...
...It's been about two months now and we still haven't heard from them! Our customer called Giben again and now we are being told that they don't know where to get the file format for this G57 Panel Saw! So this finally brings me to my question: is there anyone out there who has the .AC file format for the NEWER G57 Panel Saw from Giben? If you need more details about this particular machine, contact me and I can give you our customer's name and number. Your help would be GREATLY appreciated!
As a side note, I give technical support on a daily basis to Cabinet Pro and Door Pro users. So this lack of technical knowledge by a machinery "support" team is truly maddening!
6/1/16       #2: In need of the .AC File Format for ...
Alan F.
Frank,
I don't know if this is any different than what you have.
I have some emails from about 6 years ago when we came across this, our problem was the format wouldn't accept more than 99 parts so part 101 messed up the cutting instructions.
I think you need an AD file for the inventory sizes. The AD file can contain only one material type but can contain different size boards.
A-
Giben America AC File Format 1/1
The AC file is Giben's import/export file format. It contains the cutting
pattern data for one material. This is termed a JOB in OPTISAVE.
The file consisits of ASCII text, undelimited, fixed-field format with filename
extension AC (filename.AC)
Example:
0 1 2 3 4
01234567890123456789012345678901234567890
PARTICLE BOARD 1920110050024832125440
PARTICLE BOARD 192012002483201
PARTICLE BOARD 192013000614402
PARTICLE BOARD 192014010614404
PARTICLE BOARD 1920210010024832125440
PARTICLE BOARD 192022002483201
PARTICLE BOARD 192023000307204
PARTICLE BOARD 192024010614404
PARTICLE BOARD 1920310025024832125440
PARTICLE BOARD 192032002483201
PARTICLE BOARD 192033000614402
PARTICLE BOARD 192034020307207
In the above example, the first line is the HEADLINE and the subsequent lines
are pattern data lines. The first two fields MUST be the same on ALL lines!
Explanation:
HEADLINE
Character Position Field Description
1-15 material type (optional)
16-18 thickness (1/10 mm or 1/254 inch)
19-20 pattern number
21 record key = 1 for HEADLINE
22-26 board quantity
27-31 board length (1/10 mm or 1/254 inch)
32-36 board width (1/10 mm or 1/254 inch)
37 ABBA or headcut trim: = 0 for no or = 1 for yes
PATTERN DATA LINE
21 record key = 2 for headcut, = 3 for rip cut,
= 4 for cross cut, or = 5 for z-cut
22-23 part number
24-28 cut dimension (1/10mm or 1/254 inch)
29-30 cut quantity
AC_File_Format.pdf
6/1/16       #3: In need of the .AC File Format for ...
Alan F.
valid .ac file
1280011; 1/2" M128011 124832125440
1280011; 1/2" M128012002483201
1280011; 1/2" M128013001011201
1280011; 1/2" M12801424 76750129.980 39.500
1280011; 1/2" M12801400 767501
1280011; 1/2" M12801557 97280138.000 29.980
1280011; 1/2" M12801558 97280138.000 29.980
1280011; 1/2" M128021 112544248320
1280011; 1/2" M128022001254401
1280011; 1/2" M12802300 767501
1280011; 1/2" M12802421 94720137.000 29.980
1280011; 1/2" M12802419 93440136.500 29.980
1280011; 1/2" M128031 124832125440
1280011; 1/2" M128032002483201
1280011; 1/2" M12803300 972801
1280011; 1/2" M12803422 73600128.750 38.000
1280011; 1/2" M12803400 767501
1280011; 1/2" M12803542 92160136.000 29.980
1280011; 1/2" M12803543 92160136.000 29.980
1280011; 1/2" M128041 124832125440
1280011; 1/2" M128042002483201
1280011; 1/2" M12804300 921601
1280011; 1/2" M12804417 76750129.980 36.000
1280011; 1/2" M128051 124832125440
1280011; 1/2" M128052002483201
1280011; 1/2" M12805300 947201
1280011; 1/2" M12805420 73600128.750 37.000
1280011; 1/2" M12805400 736001
1280011; 1/2" M12805541 92160136.000 28.750
1280011; 1/2" M128061 124832125440
1280011; 1/2" M128062002483201
1280011; 1/2" M12806300 896001
1280011; 1/2" M12806413 73600128.750 35.000
1280011; 1/2" M12806414 76750129.980 35.000
1280011; 1/2" M128071 112544248320
1280011; 1/2" M128072001254401
1280011; 1/2" M12807300 768001
1280011; 1/2" M12807411 76750129.980 30.000
1280011; 1/2" M12807300 838401
1280011; 1/2" M12807415 89600135.000 32.750
1280011; 1/2" M128081 112544248320
1280011; 1/2" M128082001254401
1280011; 1/2" M12808300 768001
1280011; 1/2" M12808410 73600128.750 30.000
1280011; 1/2" M12808400 499201
1280011; 1/2" M12808511 73600128.750 19.500
1280011; 1/2" M12808300 838401
1280011; 1/2" M12808418 92160136.000 32.750
1280011; 1/2" M128091 112544248320
1280011; 1/2" M128092001254401
1280011; 1/2" M12809300 768001
1280011; 1/2" M12809411 76750129.980 30.000
1280011; 1/2" M12809300 787201
1280011; 1/2" M128094 9 70080127.375 30.750
1280011; 1/2" M12809300 793601
1280011; 1/2" M12809412 76750129.980 31.000
1280011; 1/2" M128101 224832125440
1280011; 1/2" M128102002483201
1280011; 1/2" M12810300 787201
1280011; 1/2" M128104 9 70080127.375 30.750
1280011; 1/2" M128111 124832125440
1280011; 1/2" M128112002483201
1280011; 1/2" M12811300 700801
1280011; 1/2" M128114 8 76750129.980 27.375
1280011; 1/2" M128114 9 78720130.750 27.375
1280011; 1/2" M128121 124832125440
1280011; 1/2" M128122002483201
1280011; 1/2" M12812300 700801
1280011; 1/2" M128124 8 76750129.980 27.375
1280011; 1/2" M128131 124832125440
1280011; 1/2" M128132002483201
1280011; 1/2" M12813300 384001
1280011; 1/2" M128134 2 73600128.750 15.000
1280011; 1/2" M12813300 838401
1280011; 1/2" M12813418 92160136.000 32.750
1280011; 1/2" M12813400 512001
1280011; 1/2" M12813512 73600128.750 20.000
1280011; 1/2" M128141 124832125440
1280011; 1/2" M128142002483201
1280011; 1/2" M12814300 486401
1280011; 1/2" M128144 5 73600128.750 19.000
1280011; 1/2" M12814400 736001
1280011; 1/2" M12814508 47360118.500 28.750
1280011; 1/2" M12814300 736001
1280011; 1/2" M12814410 76800130.000 28.750
valid .ad file
1280011; 1/2" M0.500 1 1G1280011-1 : 1280011; 1/2 01/31/20 1
1280011; 1/2" M0.500 1 4 197.000 49.000 111280011; 1/2" M/M, PB -
1280011; 1/2" M0.500 1 4 297.000 49.000 111280012; 1/2" M/M, PB -
1280011; 1/2" M0.500 1 4 397.000 49.000 111280013; 1/2" M/M, PB -
1280011; 1/2" M0.500 1 4 497.000 49.000 111280014; 1/2" M/M, PB -
1280011; 1/2" M0.500 1 4 597.000 49.000 111280015; 1/2" M/M, PB -
1280011; 1/2" M0.500 1 4 697.000 49.000 111280010; 1/2" M/M, PB -
1280011; 1/2" M0.500 1 4 797.000 49.000 111280005; 1/2" M/M, PB -
1280011; 1/2" M0.500 1 4 897.000 49.000 111280003; 1/2" M/M, PB -
1280011; 1/2" M0.500 1 4 997.000 49.000 111280006; 1/2" M/M, PB -
1280011; 1/2" M0.500 1 41097.000 49.000 211280007; 1/2" M/M, PB -
1280011; 1/2" M0.500 1 41197.000 49.000 111280008; 1/2" M/M, PB -
1280011; 1/2" M0.500 1 41297.000 49.000 111280009; 1/2" M/M, PB -
1280011; 1/2" M0.500 1 41397.000 49.000 111280001; 1/2" M/M, PB -
1280011; 1/2" M0.500 1 41497.000 49.000 111280004; 1/2" M/M, PB -
1280011; 1/2" M0.500 1 41597.000 49.000 111280002; 1/2" M/M, PB -
6/1/16       #4: In need of the .AC File Format for ...
Alan F.
Frank,
Ignore those patterns, they fixed a short rip issue we had
Alan
6/2/16       #5: In need of the .AC File Format for ...
Alan,
Thank you for the attempt. I appreciate your efforts!
I have the .AD file, for it has not changed from older machines. It is the .AC file that is the problem. The old .AC file has 37 non-delimited characters, while the new one has over 100 characters (I think). It's the new format that I need. (Both .AD and .AC files require headers.)
6/2/16       #6: In need of the .AC File Format for ...
Alan,
The pdf file you provided above is the exact same file structure I implemented into Cabinet Pro. When a cutlist is generated within Cabinet Pro, the AD and AC headers AND data files are generated perfectly. But when those files were sent to Giben, the response was that the format we are using from that pdf file is for their older machine, not the newer G57 that our customer has. :(
6/2/16       #7: In need of the .AC File Format for ...
Alan F.
Frank,
Can they create a simple pattern on the saw and send you the .ac and ad files?
A
6/2/16       #8: In need of the .AC File Format for ...
Hi Alan,
We have to know what each value in the AC file is and how many characters are required. So unfortunately, just getting a sample of the output files won't work. We need the file format requirements. I was working with Weinig America about a month ago implementing their MillVision file format into Cabinet Pro and had it done in one day. Their tech support was great and they knew what information was required in their data files. This experience, however, is far different.
6/2/16       #9: In need of the .AC File Format for ...
This is a sample of an AC file produced by Cabinet Pro....but it is not correct for our customer's machine. :(
UV1 0640110000124384121920
UV1 064011010431801
UV1 064011010736601
UV1 064011010088901
UV1 064011010285802
UV1 064011010946201
UV1 064011010660401
UV1 064011010536601
PREFINISHED MAP1270110000124384121920
PREFINISHED MAP127011020431801
PREFINISHED MAP127011020965201
PREFINISHED MAP127011020923901
PREFINISHED MAP127011020685801
PREFINISHED MAP127011020609601
PREFINISHED MAP127011020088901
PREFINISHED MAP127011020285802
PREFINISHED MAP127011020946201
PREFINISHED MAP127011020660401
PREFINISHED MAP127011020536601
PREFINISHED MAP127011040228601
PREFINISHED MAP127011040876305
PREFINISHED MAP127011040139701
PREFINISHED MAP127011041219201
PREFINISHED MAP127011040076201
PREFINISHED MAP127011040749302
PREFINISHED MAP127011040292101
PREFINISHED MAP127011040749303
PREFINISHED MAP127011040876304
MAPLE PLYWOOD 06401100001 2032 10160
MAPLE PLYWOOD 064011050228601
MAPLE PLYWOOD 064011050876302
MAPLE PLYWOOD 064011050152401
MAPLE PLYWOOD 064011051219201
MAPLE PLYWOOD 064011050076201
MAPLE PLYWOOD 064011050076202
MAPLE PLYWOOD 064011050304801
6/2/16       #10: In need of the .AC File Format for ...
Alan F.
I think you need an ac file for each material type color combination, that file looks like 3 materials.
6/2/16       #11: In need of the .AC File Format for ...
Hi Alan,
No, a HEADER is needed for each material. The longer lines in that code are the headers, separating the different materials, and the lines afterwards are the data fields for that material. The UV1 material had 12 spaces past it because the material file requires that 15 spaces are used up.... but they disappeared when I cut & pasted.
Anyway, for each batch of parts, one AD file and one AC file are required. Cabinet Pro produces the kind of file YOUR machine uses, but not the kind of file our customer's machine uses. The difference is that instead of using 37 characters, it uses a bunch more. :(
6/2/16       #12: In need of the .AC File Format for ...
Alan F.
Frank,
When Giben sent us sample data, they sent pairs of ac and ad files. We produce an ac and ad file for each material / face/back color combination.
Is there a paramteron the saw to take old style files?
A-
6/3/16       #13: In need of the .AC File Format for ...
hmmmm.....interesting thought. I will check with the customer.
Thank you Alan.
1/6/17       #14: In need of the .AC File Format for ...
Eddy Jean Member
Hello Frank,
I am the software engineer at Giben America. I have seen that you are having trouble with the different file formats. If you would please contact me directly at Jean@giben.com with the customer name and machine serial number, I would be happy to help.
Best Regards,
-Eddy Jean
1/6/17       #15: In need of the .AC File Format for ...
Hi Eddy,
Thank you very much! I will contact you directly with the customer's name & email so that you might get the information about his machine that you need.
I am currently working with another customer who has the same machine and we are trying to figure out the AC file thru trial and error. I think we are having success and will be happy to share that with you.
1/9/17       #16: In need of the .AC File Format for ...
Hey Eddy,
Did you receive the email that was sent to you on 6 Jan? The customer is waiting for your call but has not received it yet. Let me know if you did not get the email with their contact information on it.
1/10/17       #17: In need of the .AC File Format for ...
Eddy Jean Member
Hello Frank,
Sorry for the delay. I have received your email. I was out of the office yesterday due to illness but I will get in contact with them today.
Best Regards,
-Eddy Jean
