Subject: Re: aggregate durability
1/3/17
John Member
Hi, I am currently researching cnc options for my shop and was wondering on the durability of aggregate heads. I would have a set of 4" wide moulder knives and be cutting a lot of Extira on the machine. Would I be better of with a dedicated moulder head? Would the application put too much strain on the aggregate?
thanks
1/3/17       #2: aggregate durability ...
I have 4 different aggregate heads, including a moulder. We are very careful with our heads due to the cost, but have never had to replace them. All of them are at least 10 years old and each one has been reconditioned once. We are a custom shop and use all of them on a regular basis, but none of them in a dedicated production scenario.
My advice is, if there is money available, go with the dedicated moulder. The aggregate moulder is vital for our operation(ran 2 curved casings today), but are in no way comparable to a dedicated unit. I can say this because I have run both. You can take heavier cuts and maintain good feed rates. Also, with the aggregate heads, they stick so far below the spindle that dust collection is almost nothing. Also at 20lbs or so, we have to manually load them since the tool changer cannot handle it. With our machine the program cannot have additional tool paths. Hope that helped. My next machine will have a moulder. Feel free to email if you have specific questions.
1/4/17       #3: aggregate durability ...
WoodDust
John
How many arched casings do you want or think you'll do in a day? Maybe you should be thinking of profiling them with an end mill instead . Unless arched casing are your main business. But if you need to change knives frequently for different profiles , I see that as a lot of setup time on the Cnc.
1/4/17       #4: aggregate durability ...
Set up time is not that great with the moulder aggregate or dedicated unit, and when you use the same knives that the moulder ran the straight trims on, the match is perfect. Profile machining takes a lot of run time even at high speeds compared to just a couple of passes with the moulder head and the match is better without using really small ball ends. If you do enough of them, it pays for itself pretty quickly.
1/4/17       #5: aggregate durability ...
John Member
Thanks for the info. I was wondering about the dust collection issue with the aggregate. Extira dust is terrible and would need excellent dust collection for this. Ive been told that aggregates have better versatility, but I can get an aggregate anytime if I need to. I would just be doing a left and right motion to profile shutters with closed louvers, but it would be running all day to keep up with production. Im looking at an Onsrud and an Anderson 12 x 5 2 table with a fixed gantry. I know Onsrud is the cadillac of these machines, but Anderson has a global presence and less expensive machine. They claim to offer equal support and training, and pretty comparable specs on machines.
1/4/17       #6: aggregate durability ...
John,
Not sure Onsrud is any better than Anderson, but my experience is with Northwood and I would rate them over the two you mentioned for a variety of reasons.
With the moulder aggregate, we once ran a 5 sided mitre folded assembly cutting 2 mitres at a time in Extira. The dust was horrible. We had to curtain off the rest of the shop. The dedicated moulder units have an enclosure that keeps the dust down somewhat.
1/4/17       #7: aggregate durability ...
DOM
+1 with Northwood. We have 4 of them. very heavy machines built to run that type of stuff 3 shifts.
1/4/17       #8: aggregate durability ...
Stuart
if this is something you are going to do a lot of i would look at a 5 axis machine and not have to worry about aggregates at all. By the time you purchase two-three aggregates the cost for five axis is covered from what the reps from Biesse and Stiles were telling me at IWF. Programming seems to have come a long ways as well.
1/10/17       #9: aggregate durability ...
We have two aggregate heads, both are the grease type not meant for continuous production. The oil bath type is for continuous production. Ours are Benz, have been fine for intermittent use, poor dust control though.
