Subject: Re: Mdf routing
Mdf routing
1/25/17
Antony John Member
How to avoid breaking PVC edge, on mdf panel while routing, at tool exit
1/25/17       #2: Mdf routing ...
Will Williamson  Member
Have you tried climb cutting?
1/25/17       #3: Mdf routing ...
Gary B.
Antony,
It sounds like you are putting A part on the CNC instead of a full sheet. If the part already has banding, I always run the tool INTO the banding, not OUT of it. I also use a left or a right handed cutting tool, based on the tool compensation off the desired cut path. If the tool is compensated to the right, a normal right hand tool works well, Left for the opposite case.
Or invest in the money for something Like the leuco P-System tooling. We have one, it's amazing.
https://www.youtube.com/watch?v=vWGn9CXFfJE
I've actually done what's in the video, with the same results.
1/26/17       #4: Mdf routing ...
If you have a flat table router, your best bet is a combination of left and right hand tools. I usually only use the left hand to break the banding with a notch, and use the right hand tool for the majority of the cut. Works well for edge banding and notching solid hardwood without tear out.
The Leuco tool looks like a nice design, but you probably want the neutral point of the shear angle to be in the center of the panel thickness. Not possible with nested machining unless using pods or fixtures.
1/26/17       #5: Mdf routing ...
Gary Balcom
Mike is correct, in fact, the P system doesn't seem plausible (to me) for anything other than a Pod and Rail, because of the Z dimensions and it's large diameter. You certainly wouldn't want to try to nest with it.
1/26/17       #6: Mdf routing ...
Dan
If on a flat table router, I just but a piece of scrap up to the banding where the tool exits. No need for extra programming. Just my two cents.
