Subject: Re: Retrofit ATC
Retrofit ATC
4/13/17
Matthew Grant
I have a really old CNC with a single spindle and single drill head. Is it possible to retrofit it with an ATC? Or should I just be looking for a new machine?
The CNC I have is a Digital Tool meta machine. Don't think they made many of them and haven't been in business in a long time.
4/13/17       #2: Retrofit ATC ...
If the spindle uses tool holders rather than a collet, its possible.
Whether it's worth it is another matter.
I'd look for a new machine.
4/14/17       #3: Retrofit ATC ...
james e mcgrew Member
I have owned a digital, Bill Gleen and his son Josh have retro fitted many of them, You are looking at 7 k just for the spindle another 2-3 for cones and parts, then newer wincnc software and card 1500-2 k plus any upfit labor. so thinking 15-20 k to retrofit you are half paid on a newer machine like the Cobra ATC or the Panther.. that digital could bring 10-15 k for sign shop or low hobbiest production.. think your money through on this. those are good machines and still hold some value
4/14/17       #4: Retrofit ATC ...
Matthew Grant
Thanks James. You're right, at that cost it doesn't make sense. I hadn't even thought through the software side of it.
4/15/17       #5: Retrofit ATC ...
B.H. Davis Member
I built a 5 position tool changer for my Digital Tool DT-902 back in the early 2000's. It worked out quite well and was worth it to me as I both learned the system and had the tool changer when done.
I was lucky in that I found a good deal on a demo HSD 5-hp spindle and inverter. I also used off the shelf relays and solenoids to help keep the cost down. I did have to pay for the WinCNC tool changing upgrade.
I also found the 5-hp HSD spindle was too heavy for the stock linear guides on the machine so had to double up on the guide bearings.
In the end I had a decent machine that I used for several years before selling and upgrading to a new CNT Motion 900 router.
If you have a strong mechanical inclination, and the time to learn about all the systems involved, then it could be worth it to build your own tool changer. Otherwise a used tool changing machine would likely be a good way to go to keep the cost reasonable.
