Subject: Re: Flexicam
Flexicam
5/17/17
William Member
I have 2 Flexicam machines one runs great. am getting a spindle fault on the other. I changed the power supply. still faults out. do you have any advise?
5/21/17       #3: Flexicam ...
Maurice Phelps
What is the fault you are reading on the inverter?
5/22/17       #4: Flexicam ...
Bill  Member
its going to return a tool. the spindle is still going. am getting a spindle error the same one ill get if the air not on.
5/25/17       #5: Flexicam ...
Stephen DiCarlo Member
If air pressure to spindle is low by even a couple of psi, it will trip. Need at least 90 psi or 6.5 bar at all times at regulator on electric /control box. If your pressure goes down even from blowing chips off of the table, it will trip. I had a Stealth 2 Flexicam (2006).
