Subject: Re: Is pod and rail the best choice?
5/28/17
Mark Member
I have just started to consider adding a CNC machine to my shop.
It would be used for machining solid wood components, anything from tabletops that need radius contouring to countertops needing the same.
My thinking is a pod and rail machine is the way to go. I understand that pods can be used with some flat bed routers, but because I don't envision ever using the router to cut flat panels why go to the added expense of adding them after the fact.
Because this is the first time I've started to consider this I'm wondering if there is something I'm failing to consider?
Thanks in advance,
Mark
5/29/17       #2: Is pod and rail the best choice? ...
Jim
Website: http://totalcutcnc.com
Mark,
What is your primary product line? Is there possibility for expansion into other products?
Machines such as the Total Cut line of CNC routers are capable of both pod style and flat style cutting making it a more versatile machine for a growing company.
View higher quality, full size image (1017 X 735)
5/30/17       #3: Is pod and rail the best choice? ...
Mark Member
Jim,
Yes, I am expanding into other product lines, but it will always be solid wood components, not any flat panel type of routing.
Should that become a necessity, which I don't envision, I would just bust it down and do any further processing on the pod and rail.
Once again, solid wood, not panel products.
The more I think about it, I believe it's the right direction, I was just wondering if I'm missing something.
Mark
5/31/17       #4: Is pod and rail the best choice? ...
Kevin Member
Mark,
A pod and rail system offers plenty of options to machine solid wood and panels. There are many techniques you will develop over time. Some limitations I have encountered in the past were relating to the size of the material being processed. Some were larger than the machining area. Some were so small a holding device was needed to secure the part in order to be machined.
6/2/17       #5: Is pod and rail the best choice? ...
Michael
Another alternative ..vertical machining center. Uses the same vacuum pods but with a much smaller footprint
https://www.weinig.com/en/panel-processing/vertical-cnc-machining-cen
ters/evolution.html
6/3/17       #6: Is pod and rail the best choice? ...
Gary B.
Michael,
I've never used a vertical, and they do look intriguing. But from people I've spoke with, it's my understanding that you can't have any "drop" or "off fall" within a program. Basically, everything you machine off must be turned to dust or the machine can jam. Also, you have to work around the bottom edge "grippers". Sounds like a bad fit for solid wood work, unless someone knows otherwise.
6/5/17       #7: Is pod and rail the best choice? ...
Mike McClaran
Website: http://greenbvc.com
You can get a flat table and for less than $1000 you can get these http://www.greenbvc.com/better-vacuum-cup-table.html
to have a pod and rail in seconds.
