Subject: Re: Beam Saw problem
Beam Saw problem
8/8/17
Dan Member
We have a 2001 Casadei Linea we have been having some issues with as of late.
When we are running full Automatic program the carriage is randomly getting stuck on the rail on the way back. I've fully cleaned everything and it slides quit well. Never have an issue running forward and when it gets stuck we hold down reset and it returns back no problen and continues on.
Anyone have any ideas? Only thing i can think of now is maybe theres a overload setting on the return motor that randomly trips causing it to stop, but its not throwing a code.
8/9/17       #2: Beam Saw problem ...
Sometimes overload breakers can get a little "weak" over time. There should be a small dial on it. You can try to turn it up SLIGHTLY (10% of current setting?) to see if that changes things.
8/9/17       #3: Beam Saw problem ...
yaakov katz
which motor ,and control type?
simple by inverter?
simple by 2 speed?
servo?
which brake system?(electro mehanic on motor,or only by inverter?
all that question must answer to try focus you the optional solution
