Subject: Re: Plum Creek
Plum Creek
9/15/17
I have been getting quite a bit of substandard mdf panels from Plum Creek since Weyerhaeuser bought the company. Does anybody have an alternative board that is consistent in thickness and machines well? Making cabinets with Rabbet/Dado construction and the thickness issues are a problem. Thanks.
9/16/17       #2: Plum Creek ...
I have the same experience, in fact I posted on it a few months ago.
Not sure why this affects your style of doing cabinets though, unless you are referencing from the top of the material.
I have seen in some instances, like using ply, a land is machined before the dado. That way you have a consistent thickness where the cross pieces hit the sides.
10/5/17       #3: Plum Creek ...
Randy  Member
I have noticed some irregularities in Plum Creek also. My supplier says others are complaining but Weyerhaeuser insists nothing has changed. But, now the last order was a darker color and a lot flatter, worked fine and pulled down well on vacuum bed.
