Subject: Re: Cnc flat table multi-zone
12/10/17
Ag Member
Hi all hope your having a good day
I would like to get your opinion on the multizone option of a flat table .
Knwoing that i am using the cnc to cut full sheets and i will be lifting hardwood to cut edges
So what is the benefits of having a multiple zone ??
Will it save me some energy cost while using half of the table ??
Hope u can help me with that thank u
12/10/17       #2: Cnc flat table multi-zone ...
I don't think it will save you energy but it will concentrate vacuum on one side of the table and hold things down better.
It sounds like this will be your first machine. If that is true I would get the zoned vacuum. You really can't imagine all the things you will want to do with it until you have it. It keeps your options open.
12/10/17       #3: Cnc flat table multi-zone ...
Ag Member
Thank you for your response
Its true about my first cnc router
I am taking it slow and getting to know all about it
I will be getting a large bed 3700*2200 in cm
So if u can give me any tip i will be more than thankfull
12/13/17       #4: Cnc flat table multi-zone ...
Rob Young  Member
Website: http://www.cmsrepair.com
Bill is correct AJ. It won't save you energy but it will concentrate the vacuum. It's also important to look at the vacuum table construction. Is it an open table with a phenolic top or is it two pieces of phenolic that has a grid pattern machined in between the two. The open bed with the phenolic top will allow more volume.
12/14/17       #5: Cnc flat table multi-zone ...
In theory you will save energy. The more vacuum you pull, the less energy the pump draws so if you can close off unused zones, you save $.
How much, who knows? Maybe a cup of coffee a month? But you will save something.
