Subject: Re: alphacam tool offset number
2/19/18
Ian
Ok, I may sound like a dope here, but what is the tool offset number in Alphacam? All the info I've ever been able to muster is this - • Offset Number - this number will be the offset number that is used in the NC Code for this tool. Pretty general statement there. Can anyone enlighten me on the true function and methodology of this?
2/20/18       #2: alphacam tool offset number ...
Depends on the machine. Some posts require nothing, others need differing data. What kind of machine and control?
2/21/18       #4: alphacam tool offset number ...
Ian
holzher pro master, runs on campus
2/21/18       #5: alphacam tool offset number ...
Not sure what the post authors were looking for in that offset field. I have seen posts where the offset field needs to be the same as a sub-program on the control that sets up a particular spindle, saw, drill, etc. Some simpler posts allow the offset to be blank because that data is not needed. I have also seen others that just need the diameter(radius) offset value of that tool put in. I wish I could help, but it depends on how the post processor was constructed and how the offset tables on the machine are arranged.
2/21/18       #6: alphacam tool offset number ...
Could be the same as the tool number.
For my Biesse Arrow with OSAI control the syntax is like this: T17.17 meaning tool 17 running with offset 17. Note that this only really using the length offset because the CAM software generates the g code based on the tool dimension.
2/22/18       #7: alphacam tool offset number ...
Dropout could be right, but some controls with limited offset numbers available in the offeset registry have diameter or length values that don't necessarily match the tool number. They just have values that match available offsets. Again, this is post processor and control dependent. Alphacam's interface is set up to output to thousands of different machines and types, so that is pretty generic, and not all available data fields are relevant to some installations. Try different values and see what the code looks like.
3/13/18       #8: alphacam tool offset number ...
Boyd Member
Ian, with our Omnitech CNC Router and alphacam, the tool offset refers to the tool position (first number is the router=1 or drill head=2), second is the tool position in the carousel or drill head. (I.e. offset 11 is router, and the tool in position #1 of carousel), which is always my 3/8" compression cutter.
