Subject: Re: Another feeds and speeds question
4/24/18
Pdub Member
I typically use manuf. recommendations for RPM and feed rate on a per bit and per material basis. I look at the surface and then feel the bit after it has cut. If the surface looks good and the bit doesn't burn my hand, I leave it.
We've been using HDF in lieu of MDF for certain parts lately, and when I checked the bit today, it was too hot to touch. Makes sense, that material is harder than MDF. So, where do I start adjusting? Do I change the chip load? Do I lower the RPM or feed rate 1st? Speed them up?
We use a Vortex 3184XP if that makes any difference.
4/24/18       #2: Another feeds and speeds question ...
David Egnoski  Member
Website: http://www.richmondcabinet.com
It's all about chip load. For your material I would start at .015 to .018 chip load. For the tool you are using that would be around 550 ipm @ 18k rpm.
4/24/18       #3: Another feeds and speeds question ...
Bill Member
I think
,doesn't burn my hand
is not a good test. Our main nesting bit after cutting sheets of 3/4 plywood is barely above room temperature.
4/24/18       #4: Another feeds and speeds question ...
Pdub Member
I was using a chipload of .02 for MDF. So, a harder material would use a smaller chipload?
This begs another question. If you're using the same chipload, what is the difference in how fast you move as long as you're sticking to the formula and maintaining the chipload? I'm guessing holding power is a big one.
"burn my hand" was a bit of an exaggeration. I'm making sure the bit is just a "little warm" if at all.
4/24/18       #5: Another feeds and speeds question ...
How may passes?
How thick material?
Vacuum and chip/dust evacuation are the limiting factors.
What do the chips/dust look like? Chips or dust?
If dust, you need to either increase chip load, change tool to a larger upcut portion, or increase dust extraction.
If you're making doors and profiling the edge you could even consider a low helix upcut bit.
4/24/18       #6: Another feeds and speeds question ...
Pdub Member
3/4" material in 1 pass. Compression bit. Need to look at the specific dust. On another material now, so will check that out.
We've got a pretty powerful dedicated dust extractor. Though, it's a compression bit, so obviously it stays in there a bit.
10/5/18       #7: Another feeds and speeds question ...
Nate Member
My goal has been recently shooting for .012" chip load when cutting. How many different materials is this a good speed for? I am cutting mostly 3/4" plywood but am getting into 2 sided melamine also.
10/5/18       #9: Another feeds and speeds question ...
That chip load on a compression spiral will kill the bit.
