Subject: Re: Parallel processing
Parallel processing
5/13/18
Mark Member
I have a new Biesse Rover K rail and pod machine and so far my programmer and myself haven't figured out a way to get the machine to parallel process.
It just seems to us that we can do it, but for some reason, we can't get it to take.
Any advice or help would be greatly appreciated.
Mark
5/14/18       #2: Parallel processing ...
Tyler Lauzier
Just call biesse tech support, with that machine you have lifetime telephone support. They will take over your computer and show you how to do it
5/15/18       #3: Parallel processing ...
Mike  Member
Mark you will need to see if your machine is set up from the factory for Pendulum processing. If it is Tech Support can help you.
5/16/18       #4: Parallel processing ...
Chevy
open your machine settings and check to see if your boring block is set for mirroring, if your boring block is not set for this you cannot mirror parts,,Spingle(Rout) is set by defaut,,
hopefull this helps, if you cannot solve this please let me know i will look into this further,,
