Subject: Re: Vacuum Lift Problem
Vacuum Lift Problem
5/30/18
Jarin Smoker  Member
Anybody else have an issue like this? (see picture) the vac tube just sucked itself closed. Earlier today I fixed two leaks on the lift and now it has a little more lifting power but the pipe closes on itself. Anybody have any ideas? Sorry the picture came through sideways.
View higher quality, full size image (5312 X 2988)
5/31/18       #2: Vacuum Lift Problem ...
Bill Member
It looks like that is the wrong hose? Did you buy it used or replace the hose?
5/31/18       #3: Vacuum Lift Problem ...
Jarin Smoker  Member
I did replace the hose. It's made for a vacuum lift, are there different kinds?
5/31/18       #4: Vacuum Lift Problem ...
Bill Member
I am not sure. That looks like a Smaltz, I'd call them.
I imagine there are different weights of hose depending of what weight the unit is meant to lift.
6/4/18       #5: Vacuum Lift Problem ...
cabinetmaker
Look for kinks in the vacuum hose its self - from the pump to the top hanger
Mine does the same thing- Anver, and it was from kinks
