Subject: Re: Enroute 6 post processor
6/8/19
Daniel W Antes Member
Website: http://danielantes.com
Anyone using Enroute 6 with an Anderson Stratos Pro? I would love to see your post-processor. Mine is not giving me the code I would like.. Thanks
N14 is my Z move with a feed of F30 but I am not getting an XY feed rate posted until N23. Killing my throughput as well as my tooling since the XY moves are at F30 until N23 and this is happens throughout the file.. I am wondering if someone has a post that works. I am behind on job and need to get something done before Monday.. Thanks
N12 G0 G90 G54 X1.9567 Y0.324
N13 G43 H13 Z0.56
N14 G1 X1.9567 Y0.324 Z0.2275 F30.0
N15 G3 X2.1835 Y0.3776 R4.8534
N16 G3 X2.3427 Y0.4295 R1.6403
N17 G3 X2.6096 Y0.5967 R0.81
N18 G3 X2.8504 Y0.9377 R1.1144
N19 G3 X2.8409 Y1.0036 R0.0617
N20 G3 X2.777 Y1.0225 R0.0617
N21 G2 X2.5995 Y0.9841 R1.3154
N22 G2 X2.2239 Y0.9572 R2.9175
N23 G1 X2.03 Y0.9542 Z0.2275 F200.0
6/8/19       #2: Enroute 6 post processor ...
BH Davis  Member
Is there a .cnf file for your post at:
C:\Enroute6\ndrivers ?
If so you might be able to edit the data there to accomplish what you need. Be sure to back up the file first before making changes.
Also have you tried editing the parameters under SETUP, MACHINE SETUP within Enroute?
As to other posts that might work better you can just try any of them that come with Enroute. That would be in the SETUP, MACHINE SETUP window. I run the current version of Enroute6 Pro and there are two post options under "Stratos Pro". The first thing to do would be to try the other one if you also have two available.
Or contact Enroute tech support. They are very accessible and have always been helpful when I've called.
7/9/19       #3: Enroute 6 post processor ...
BH Davis  Member
Did you ever get this sorted out the way you wanted?
