Barcode scanner issues
8/28/14
Thom Member
Hello all,
We have 2 CNC's, Busellato and a Jet that both run with Genesis Evolution 5.0 on Windows XP. We recently purchased a cad/cam program and for the most part, everything works fine. The only issue is that the barcode scanner will not dedicate to a port. After a reboot we need to manually find a port. Anyone have any idea how to dedicate a port and make it stick?
Thanks in advance.
9/26/14       #3: Barcode scanner issues ...
Bill Blackmon  Member
Website: http://www.casadei-busellato.com
Thom,
In the C:\evol\bin folder is a file called tpa.ini. Make a copy of the file in case you need to revert back to the original version. This file affects many programs so don't edit it without a backup. Look for a section called GESTBCOD and under it you will see where a COMM port is assigned. It is likely set to a port that the inverter or digital read outs is using. Change the number to the port you typically set it to manually. Save the file and reboot. Hope this fixes it for you.
