Winner90 indice.prg question?
9/28/14
Matthew Durand Member
Hi
I have lost most of the list in my indice.prg file in the SORG folder, I still have all the programs in the folders NOC, SPC,SRG and TAB but are unable to open the programs in program editor.
Is there a way of getting all these programs back onto the indice.prg list
9/29/14       #2: Winner90 indice.prg question? ...
Brian Personett
Just delete the Indice.prg. The hard part will be you'll have to import all the programs and save and compile them individually. Once you delete the indice.prg, when you start saving and compiling, Winner90 will create a new indice.prg. All of you programs should reside in C:\\Winner90\Mod1\Sorg\Srg then in the individual folders. Open the program editor, File, Import, then set your path and tell it all files. Open the programs and saveas, as you'll have to add the first letter back to the program.
The issue I suspect is you have too many programs, which will cause your indice.prg to crash. 600ish is the limit, give or take depending on size of programs. I typically delete everything when I get near 450. If you have regular programs that you use over and over, I would keep them elsewhere. I have about 70 parametric programs that I leave in place, but all the stuff I run everyday, I delete it after the job is completed.
If you have an problems feel free to drop me an email. Us legacy Busellato guys have to stick together.
9/29/14       #3: Winner90 indice.prg question? ...
Thanks Brian
Yeah that works, blimey gonna take a few weeks to redo all that but positive side i dont have to write all the progs again
Cheers for getting my out the sticky stuff :-)
6/24/15       #4: Winner90 indice.prg question? ...
Mal
I have a Busellatto Supermaster H150 1996 model,i need the software for it and im told its winner90 or PTP1000,can you advise me please,Cheers
Mal
6/24/15       #5: Winner90 indice.prg question? ...
m9g
Hi mal
Contact busellato they could probably attach winner 90 to an e-mail or even ask them for genesis which is the upgrade to winner90
6/24/15       #6: Winner90 indice.prg question? ...
Brian Personett
Mal, contact Casadei Busellato, they will have a copy of your software. They can email it to you. They will also be able to tell you whether it's feasible or not to upgrade to Genesis.
Casadei-Busellato Service
