Cabinet Door Tooling
10/3/14
Todd Scholl
Website: http://tschollfinewoodworks.com
Currently we make our cabinet doors in house. We make them 1/8 over-sized in width and length. We then square them on a vertical panel saw. We have tried squaring them on the CNC but we get too much tear out on the end grain. If you are squaring cabinet doors on a CNC what type of tooling are you using? What speed and feed rates?
10/3/14       #2: Cabinet Door Tooling ...
We square doors on the cnc. We get no tear out. But we don't just take a trip around the door.
We use counter rotating tooling so we don't blow out end grain. We cut to the middle.
We use Vortex 1/2" dia compression cutters.
The feed and speed is what is recommenced in their catalog. I can look that up if you like.
10/3/14       #3: Cabinet Door Tooling ...
Todd Scholl
Thanks I can give them a call. How are you holding your doors in place?
10/3/14       #4: Cabinet Door Tooling ...
Vacuum, make sure you cover most of the rest of the spoil board. We use hardboard to do that. The biggest problem is placing the door on the table. The pins are not accurate enough. As the doors get large (very large) it becomes a problem.
10/3/14       #5: Cabinet Door Tooling ...
Here is the chip load chart it gives feeds and speeds for cutters and material.
Chip load chart
