Genesis list manager question?
10/9/14
Matthew Durand Member
So I am temporarily running the busellato with genesis until company take delivery of SCM machine i'm going to be running and then the previous operator of the busellato will go back on it..
What I am trying to do but for some reason cant is add another line in list manager and then save it.
For example open one list program which brings up two programs, machine one side of board with one program, flip it over then run second program
Now a few years ago i ran a busellato with winner90 and i could add as many lines to list manager as i wanted and save it as one list program so both programs come up when the one list program is chosen
I can add another line in genesis but when click on file the "save as" is greyed out, if i click on the save button it looks like it saves but doesnt.
One thought i did have is when the machine is turned on i have to press 'CTRL * ' to enter a password and have been told to put in "test" - I was wondering if this limits what can be done in list manager and should there be another password i should be entering.
Appreciate any help on this please
M9G
10/10/14       #2: Genesis list manager question? ...
I believe you have a password problem. I believe my machine is newer.
It has a program that is a password generator. You run the program and it generates a 4 digit password. Down in the task bar on the right hand side there is a yellow key, if you click on the key and enter the password it allows full access.
I don't think that will work on your machine but I do believe you have a password level problem.
Good luck
10/10/14       #3: Genesis list manager question? ...
Dan Member
Try clicking on the little yellow key that Bill mentioned, and enter the letter h as the password.
10/17/14       #4: Genesis list manager question? ...
thanks guys
Great technical support at Busellato sorted the problem, needed to add Rem to a line in the tpa.ini file in windows folder to enable lister in genesis list manager
All sorted now thanks
10/3/15       #6: Genesis list manager question? ...
John
Hello Matthew. Is it possible you could post or email me the full steps to this solution.
Many thanks
John
