Microvellum - Labels
10/16/14
Ted Member
Has anyone figured a way to print labels from Microvellum without using there labeling system. We upgraded from ver 6 to 6.7 but didn't have our labels updated before we canceled our service contract. We now receive misprinted labels and since we canceled our service contract Microvellum will not give us help with this. I was thinking if I could export information from Microvellum I would be able to use third party label software to print labels as needed.
10/17/14       #2: Microvellum - Labels ...
Gary B.
Ted,
Are you sure you are running 67, not the newer version 7 program? I still run 67 for production, but it is old..(I was running the same update 5 years ago).
If you mean 67, All the data you need for labels on a work order reside in an access database....it wouldn't be awful hard to create an access application that would pull the required information together for a label. Like Alis, you'd have to pull up the specific job, and path to the required database, but it's doable....
However, if you have to have someone create this for you, it's probably less money just to get back on support and have them help you out. Also, I like the MV reports, they have alot of ability thanks to the underlying stimulsoft report engine.
Why aren't you on support? I wouldn't want to run any software nowadays without support, especially a mission critical piece of software. I guess what I'm saying is the easiest, cheapest solution is to hop back on the bandwagon with support. You can download all the generic label reports and be up and running pretty fast.
