Double Drilling in HOPS (Holzher)
10/17/14
Frank D. Jimenez  Member
Website: http://www.cabinetpro.com
I have a customer who has a Holzher router and is experiencing something very weird: on some of his drills in his drill bank, a hole is being drilled twice, even though the code calls for one plunge! On some of his drills, with the exact same code, the machine drills only once....as it should. On other bits, the machine drills TWICE! Holzher will not help the customer even though he's spent enough on his router to buy a house, so I was hoping someone here could give some ideas as to why this is happening.
Here is the code that shows a SINGLE drilling command:
VARS
DX:=2438.4
DY:=1219.2
DZ:=15.9
START
FINISHEDPART (DX,DY,DZ,0,0,0,0,0,'BIRCH PLY',0,0,0)
CALL HH_PARK (VAL PARK:=1,X:=0,Y:=0)
ToolD (501,_VE,_V,_VA,_SD,_ANF,'1')
DRILLING (235, 463.6, 7.5,6.4,0,0,0,1,0,0,0)
ToolM (3,_VE,_V,_VA,_SD,_ANF,'0')
SP (773.1,519.1,25.4,0,1,_ANF,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0)
G01(773.1,519.1,-0.2,0,0,1)
G01 (1.6,519.1,-0.2,0,0,1)
G01 (1.6,1.6,-0.2,0,0,1)
G01 (773.1,1.6,-0.2,0,0,1)
G01 (773.1,519.1,-0.2,0,0,1)
EP (0,_ANF,0)
We are meeting via remote support this Sunday to try and figure this out. Any help would be GREATLY appreciated.
10/18/14       #2: Double Drilling in HOPS (Holzher) ...
jerry Member
check to see if there are any duplicate vectors for the holes.
10/18/14       #3: Double Drilling in HOPS (Holzher) ...
Thank you Jerry for your response. Could you please explain how we would check for the existence of duplicate vectors?
10/18/14       #4: Double Drilling in HOPS (Holzher) ...
cabinetmaker
check to see if the machine is doing the same with a basic program from the machine editor. If so, than you might have problem in the library and a bit may not be symmetrical to itself and so it may be choosing to drill twice. I had this happen in a Biesse machine once.
10/20/14       #5: Double Drilling in HOPS (Holzher) ...
Thank you for your responses. It turned out that the customer had defined two bits in his Holzher's Library to be precisely the same. Holzher's controller was reading the code correctly and assigning it to each of the two bits he defined on his router that were identical. Changing one of them on his router so that they were unique solved the problem.
10/20/14       #6: Double Drilling in HOPS (Holzher) ...
cabinetmaker
Good Deal ! Sometimes its just something like this can be such a time wasting aggravation. I am so glad it worked out for you and him. I hope that he is very productive moving forward
10/20/14       #7: Double Drilling in HOPS (Holzher) ...
cabinetmaker,
Yes! He and I spent almost all day on this! I even changed the post to German because his machine wrote a little program in German and it worked. But our German version didn't work either! So after we finally figured out the mistake, I put the commands back in English. But he and his son are happy campers today....and that means I'm a happy camper too! So it wasn't a waste. We all learned more about the Holzher router than we knew before we started. :)
