Second Vac on New CNC
10/22/14
John McGinnis Member
I purchased a new CNC recently. I also bought a second 10HP Becker pump for extra hold down. However, the machine has been delivered and still the second pump has not arrived. I am being told that the second pump may or may not fit under the frame. If not it would be installed behind the machine. I would like to see it underneath (seems like a cleaner package) but I have been told that having 2 pumps under the table will produce too much heat and they can be damaged. Anyone have any experience with this issue?
10/23/14       #2: Second Vac on New CNC ...
james mcgrew Member
I would imagine that would be a good bit of heat, my big concern would be the dust build up and lack of clean (out of sight, out of mind) I have mine at 7 feet from machine behind a sound proof wall, we have some to open the door a bit because if we cannot hear it some have been known not to turn it off !!
I like to use an compressed air wand and keep them clean
10/24/14       #3: Second Vac on New CNC ...
We have our pumps under the outfeed table and are looking to move them. They make too much heat.
10/24/14       #4: Second Vac on New CNC ...
We have a 40hp screw and put it out in a shed near the building. We had a 10hp Becker on our first router. Wasn't enough and was loud. Hence our shed idea. Shed has a big ventilating fan and recirculates the air back into the shop in cold weather. Almost all of the electricity used turns into heat.
12/10/14       #5: Second Vac on New CNC ...
George  Member
Website: http://www.allstaradhesives.com/
What size tables are you guys running? to run 2-10 Hp pumps?
