Rake / Pusher on new CNC
10/28/14
John McGinnis Member
I am just having my new Busellato Easy Jet installed and I can't seem to wrap my head around how the rake works. If I am machining a 4x8 panel the rake drops down about 3" before it gets to the panel. Problem is that it drops all the way down to the table and tries to push my spoil board off too. I can always just use a longer spoil board but it seems weird to me that I wouldn't be able to use a 4x8 spoil board in conjunction with the rake. Anyone out there have a rake on your CNC? How does it determine when and how far down to drop?
10/29/14       #2: Rake / Pusher on new CNC ...
Phil B
I would assume you would need to screw down your spoil board and there should be a stop on the stroke for the rake.
You purchased this new, I assume they installed it with a factory trained technician?
Did they not address this? If not, what a shame. I would be on the phone with Busellato/SCM and have someone out there to do the job right... right now.
10/29/14       #3: Rake / Pusher on new CNC ...
We have a Busellato with a rake. The spoil board needs to be longer. You can control where the rake drops. You need some wiggle room behind it because the end scrap will move and get under the rake.
It is a great feature.
10/29/14       #4: Rake / Pusher on new CNC ...
Bill Blackmon  Member
Website: http://www.casadei-busellato.com
John,
The unloading device drops just outside the reference point for the panel. It "rides" on the spoilboard. This arrangement has the advantage of not requiring adjustment as the spoilboard thickness changes but does require a "landing" for the device. The attached picture shows a strip attached with the included nylon screws and machined for the X reference pin. I'll send you the program to make the strips.
View higher quality, full size image (1127 X 521)
10/29/14       #5: Rake / Pusher on new CNC ...
I have my machine set up to do all of my panels on the left of the machine. I guess I'll just have to use a longer spoil board?
