Driliing speed/feed
1/31/15
Hi All
Sort of in response to a post about a shopbot in another forum and my own curiosity, what are people using for drill bit material, speed and feed rate in melamine and MDF?
I read somewhere that nested cnc is 30% cutting and 70% drilling, (not sure I agree) but in any case, it's a lot of time and it'd be nice to get it done as fast as possible.
Thanks.
2/1/15       #2: Driliing speed/feed ...
Gerry
We drill with carbide or carbide tipped bits.
We use 6000 rpm and 100 ipm mostly.
I would be interested to see where other shops are on this.
Gerry
2/2/15       #3: Driliing speed/feed ...
Snaglpuss
We use TiN coated drill bits for MDF and ply.
14500 rpm and around 75-100 ipm downfeed.
Sometimes peck drilling mostly straight downfeed through drill.
Carbide brad point on melamine , but don't do much mel.
2/2/15       #4: Driliing speed/feed ...
cabinetmaker
We are running carbide bits. Lots of melamine and plywood. Not sure on the feed and speed.
We have a drill bank with 20 drills- 10 in the y and 10 in the x 8- 8mm and 12- 5mm We dowel our cabinets.
Drill is much shorter for us with the head config we have about 15% max unless lots of drawer box parts then 25%
2/4/15       #5: Driliing speed/feed ...
Aaron
Brad-point carbide dowel drills. 175 IPM @ 5000rpm, one poke in sheet goods. Hardwoods peck drill 3/8"/pass
