broken bits
3/12/15
We've been using Onsrud Marathon 3/8" compression bits for quite awhile. Much better life than the uncoated kind. Once before we had some premature breakage and they replaced them no problem. The last dozen have all broken. Usually within a few inches cutting 3/4" melamine with a 2 flute, 1 1/4" CL bit, ramp in, 600 ipm,16,000 rpm. Bits run cool. We are now running some well worn ones that had been taken out of service because they were starting to show their age (dull). When it first started we changed to a new tool holder and new collet. The tooling salesman is coming this afternoon.
Anyone else using these bits?
3/12/15       #2: broken bits ...
Zach Froble
Had the same problem with a batch of 57-280 1/4" down cut spiral. Would break after a few dado cuts following all their recommendations for speeds and feeds. Never had a problem with the 3/8 compressions.
3/12/15       #3: broken bits ...
B.H. Davis Member
I had a similar problem some years back with a batch of Onsrud HSS bits. They replaced them after I returned them for review.
3/13/15       #4: broken bits ...
CRIS
Had the same problem, turns out it mas table bearings changed the table bearings, problem solved.
3/13/15       #5: broken bits ...
cabinetmaker
Larry are the bits black after they come off ?
We are running @ 800 ipm and our tool life has quadrupled. We are running a return onion skin, the operator can barely keep up, the force and speed was moving parts around even with a 40hp during a clean cut.
3/14/15       #6: broken bits ...
Not Black. You can grab the bits as soon as they stop and they are just warm, not hot. So our chip load is OK. We've run this same bit for over a year and had really good luck with them. The solid carbide bits we used to use didn't hold up well cutting HPL laminated board. These coated bit have. I'm guessing the factory has a difficult time controlling the process used to coat them, resulting in very brittle or even fractured bits. I'm sure their long life cutting HPL was due to their being very hard edged. Fine Line!
