(2064) (a64) inverter alarm
3/12/15
Bob Member
I just have have inverter error on omnitech seelex Pal CNC with fanuc controller ;
Can somebody help me with issue ?
View higher quality, full size image (2448 X 2448)
3/13/15       #2: (2064) (a64) inverter alarm ...
yaakov
look on the invereter display what is the error code
3/13/15       #3: (2064) (a64) inverter alarm ...
Will Williamson
Can't you call Seelex tech support?
3/13/15       #4: (2064) (a64) inverter alarm ...
Bob Member
Looks that is overheat.
First i try to turn off machine for couple minutes and didn't work.
After i left machine for about 1 hr and looks everything is fine now
Thanks anyway
3/13/15       #5: (2064) (a64) inverter alarm ...
cabinetmaker
Remove the air filtration in front of the circulation fan and check for a blockage
