Does good quality plywood exist?
4/17/15
Andy H Member
I'm going to be cutting out some monograms and other similar items that will need more strength than mdf due to some narrow cuts. All the 1/2" plywood in my area is essentially garbage with a bunch of voids. Can you even find any good quality ply that is solid and stable?
4/18/15       #2: Does good quality plywood exist? ...
baltic birch or other euro hardword plywood
4/18/15       #3: Does good quality plywood exist? ...
Andy H Member
I haven't seen any Baltic birch locally. I may have to expand my search. One plae does have Russian birch, but it's 5'x5'. I could make it work, but it's not ideal for my 4'x8' CNC in the long term.
I'll give it a shot for now and look for some Baltic.
4/18/15       #4: Does good quality plywood exist? ...
I have the same machine size/sheet size problems and I either rip 1' off or rip in half depending on what nests better. Russian birch is pretty much the same thing, glue lines are darker is the only difference I notice.
4/18/15       #5: Does good quality plywood exist? ...
B.H. Davis Member
I've used Appleply before that is similar to Baltic Birch. I believe that is a brand name and not an indication that it is wood from an apple tree.
It comes in 4x8 sheets.
4/20/15       #6: Does good quality plywood exist? ...
DOM
Website: http://www.naply.com
Sure does. We stock 5x5 4x8 4x10 and 5x10 and can make up to 7x20. 3mm to 2inches thick. Russian Birch. Check us out.
8/20/15       #8: Does good quality plywood exist? ...
Andy H Member
I ended up using the Russian birch for a few projects. I liked the quality of the material, but it doesn't have a very attractive face and is very fuzzy on both the faces and the cut edges. I had to spend too much time sanding.
I asked the manager at the place where I got the Russian about Baltic Birch, and he couldn't seem to find anything different. Seems many places consider them one in the same, but the face veneers differ in appearance.
