CNC Vector speed
4/26/15
Scott Lesser Member
In contemplating cnc machines will a 100m/min vector speed vs. 68m/min have a material effect over a years production?
4/27/15       #3: CNC Vector speed ...
Mark
100m/min is really flying, a typical cut is way slower, in the neighborhood of 10, 20 or 30 m/min for one two or 3 flute tools respectively at around 18Krpm. So by vector speed you must be referring to no load rapid travel. This is most often used in going from park to start, finish back to park between cuts and the bigger one, tool changes.
If so, then it depends on how much production you do in a day, what your tool strategy is, what type of tool changer you have (static or ride along) and how often you change tools.
Nearly all shops who operate CNCs run the machine sporadically, myself included. Anywhere from 5 to 25 hours per week on average I run 20 typically in a pretty busy commercial shop. The total times added for a slightly slower but still pretty fast (68m/minute is still way faster than a typical cut) is negligible for me and most people. You might be able to shave 20 seconds off an 8 to 12 minute sheet with a faster rapid if you have a static tool rack. If the tools travel with the head, even less.
I think this all speaks to the robustness of the drives more than a real time issue. If you are a really high volume production shop, maybe it is an issue, but a lot more comes into it at that point.
4/27/15       #4: CNC Vector speed ...
Scott Member
Thanks for your response Mark. A little more info. We run parts on the CNC, it's not a nested machine. We are also higher volume, running the machine around 35-40 hours a week with anticipation of even increasing the hours in the near future. I realize the vector speed is the no load travel speed and just wondering over the course of a year if the difference in the vector speed will add up like throwing change in a jar or if it is really negligable.
Thanks for any response
4/27/15       #5: CNC Vector speed ...
Mark
If you are running that much, It is worth doing a time study to see just what kind of benefit you are looking at. I nest myself, so I have less of a gut feel for your situation, but likely a setup like yours does fewer tool changes but does a home run for each part. Perhaps you can figure your total distance traveled per typical part cycle and use 100m/minute to gauge your rapid time per cycle? This ignores acceleration of course, but it is a place to start. Do you pendulum process or load while idle? how many cycles per day?
If a cycle with loading took X seconds and you gain 1 second per part......Lots to think about. I doubt it would be the most important factor in choosing a new machine, but not irrelevant either.
4/28/15       #6: CNC Vector speed ...
Scott Lesser Member
Thanks for your response Mark. Your last line hits the mark. "Not the most important factor, but not irrelevant either"
I have more studying to do.
11/15/16       #7: CNC Vector speed ...
Doug Member
Does anyone have any more accurate data on this? Say for an "average" sheet of cabinet parts for frameless MDF with blind dado, shelf/hinge and pilot holes.
We are comparing nesting machines, SCM Pratix S18 (35m/min vector) and Biesse Rover A (100m/min vector), both with static tool holders and 12 tool drill blocks.
Of course the SCM salesperson tells me it won't make any difference but I don't want to find that we are waiting on the machine during busy periods.
