Inverter error message
5/5/15
Dan Member
We have a Busellato Jet 4 RT Router running Genesis, and have suddenly run into some issues. Yesterday it ran one pattern and then an error message appeared saying "safety device not reset". Checked all the safety switches and latches, no problems, voltage was good also. Shut the machine down for the night, and this morning it worked for about an hour, but now is giving "inverter not okay" and "inverter serial not okay" messages. Any ideas???
5/5/15       #2: Inverter error message ...
John McGinnis Member
I had a similiar issue on my Busellato Easy Jet. It was just a tripped breaker in the electrical cabinet.
5/6/15       #3: Inverter error message ...
cabinetmaker
If you have an air conditioned cabinet make sure and clean the intake filters every day @ start up. Just like vacuum pump filters
5/7/15       #4: Inverter error message ...
Dan  Member
Website: http://www.stgermaincabinets.com
Thanks guys, ended up being a bad contactor in the safety circuit. Pulled it out, cleaned the contacts and it works well now.
    • Country Saw & Knife
