BIESSE ROVER K 1532 G - INSUFFICIENT PRESSURE ERROR
8/6/15
aNTONY joHN Member
DEAR FRIENDS,
WHEN I START MACHINE (BIESSE ROVER K 1532 G ), I AM GETTING ERROR - INSUFFICIENT PRESSURE.
MACHINES PRESSURE GAUGE SHOWING 7.0 BAR.
PLEASE HELP.
THANK YOU.
8/6/15       #2: BIESSE ROVER K 1532 G - INSUFFICIEN ...
dustmaker1
Maybe bad sensor, bypass it and se if it starts.
9/21/15       #3: BIESSE ROVER K 1532 G - INSUFFICIEN ...
Mike McClaran
Website: http://www.greenbvc.com
My guess is that your sensor for air pressure is a bit out of adjustment. Turn the air up to 8 bar and see if it will start. If it does then we know its out of adjustment. Do not, I repeat, do not leave it at 8 bar. Follow the air coming in and you will see a sensor early on the line. either the sensor has failed(not likely) or it needs to be turned 1/2 turn counter clockwise.
2/5/16       #4: BIESSE ROVER K 1532 G - INSUFFICIEN ...
Tony Member
Its solved by cleaning pressure sensor
    • Better Vacuum Cups, Inc.
    • Country Saw & Knife
    • Charles G.G. Schmidt Co.
