Many ?? About Buying a Used CNC
10/5/15
BigTup
I'm looking to replace my SCM point-to-point with a nested base machine, and I have some questions-
1. I flying out to see a machine this week in another state, I'll give a deposit, and give the balance when the machine is picked up in 3 to 4 weeks. How do I ensure that the deposit money won't be spent, and the machine sold to someone else? An escrow account of some kind?
2. I feel like I should be there when it's being loaded up, and I assume I'll hire a rigger, and hire a separate trucker to deliver it. And hire a local rigger to unload at my shop. Is this the best way?
3. What if the machine gets damaged during loading, or in transit?
4. Will I really have to pay $1,000 just to transfer a software license?
5. What about getting rid of the machine I have, an auction place or some other way? I won't want to keep it connected and running for a month or 2 while I wait for it to sell.
Any other tips or advice would be appreciated. Many Thanks.
10/5/15       #2: Many ?? About Buying a Used CNC ...
2. I've used riggers before, not cheap but did fine.
3.Damage: check with the rigger. In transit. Trucking companies have very little insurance coverage. Maybe you can buy a rider from your insurance company.
4. They all have different fees. You may be able to continue using it but won't have any support.
5. I listed a machine with a dealer that put it out to other dealers. Try putting it the woodweb buy/sell. Older CNC machines don't bring much.
10/6/15       #3: Many ?? About Buying a Used CNC ...
Been through this 3 times in the last 2 years. I only buy used equipment.
It is probable that once the machine is moved and re-installed there will be some gremlins. Circuit boards shift and wire connections and relays jiggle loose. No big deal, just a bit of time.
My suggestion is to do the install and setup yourself if you can. That way you will learn much more about the machine than otherwise and you will not be dependent on a tech. My experience is that machines break down at the worst time and if you know it well, you're less likely to need a tech.
Make sure you get the manuals!!!
As far as software goes, figure out what you really need, not what comes with the machine. I'm running a 2 spindle machine with a drill block using $200.00 software. To be fair, I can't use the horizontal drills, but I don't need them anyway.
Just expect to put some time into this but it should be worth it.
10/7/15       #4: Many ?? About Buying a Used CNC ...
Chris
Where's the location of each machine
