CNC Safety Matt Option
10/7/15
Jon Member
Our Morbidelli Author 444 mats seem to have gone bad - they are not enabling us to operate - ther are 3 of them.
Are there an after marker / alternative cheaper safety mat that anyone can recommend?
10/8/15       #2: CNC Safety Matt Option ...
Jumper them out?
10/8/15       #3: CNC Safety Matt Option ...
Frank
Yes by passing safety device is always a good idea. While you are at cut the seat belts in your car.
10/8/15       #4: CNC Safety Matt Option ...
My point was that you are not slaved to the mats. Replace with a light curtain or pull string or something.
10/13/15       #5: CNC Safety Matt Option ...
Joe Fitzgerald
Are you sure it's not the contactors failing? They're easy to test if you know what you're looking at.
I've seen forklifts parked on those mats and they end up fine. As far as I've heard they're not wear items.
And I seriously doubt you could replace the mats simply with a reer vision or similar device as I've serviced machines with both.
10/13/15       #6: CNC Safety Matt Option ...
Jon Member
Hi all
it ended up being the foam between the mat metal layers
The mats have become rigid over the years and in combination with the foam deteriorating there was an open contact.
We sourced a local mat to get us out of trouble - we had no idea that the mats were so basic - we were told by the technicians that they had a smarts about them - like a motherboard - typical!
Note: with Xilog Plus as a program the light curtain and cable saftey systems wont work - It needs a contact mat. the light curtain can be adapted to the machine safety switches for complete shutdown only
10/16/15       #7: CNC Safety Matt Option ...
Rich
We replaced our mats with new mats and control module from Pinnacle systems. It was a fairly easy swap and the mats are bulletproof. we have not had any issues since we swapped over 10 years ago.
Pinnacle Systems
10/26/15       #8: CNC Safety Matt Option ...
Mike McClaran
At BVC we are a TapeSwitch dealer. Extremely strong and likely will last the life of the machine. 909 606-0140
http://www.greenbvc.com
5/18/20       #9: CNC Safety Matt Option ...
Melvin Chupp Member
My Morbidelli had an aftermarket light curtain installed. At first it would power down the machine but we were able to get it to work perfect without powering down. I then took it out completely as it did not work in my facility. I have a button that tells xilog that I have stepped on the mats. I have a complete electric eye and light curtain set for sale if someone is interested.
    • Country Saw & Knife
