vanes for vacuum pump
10/27/15
Eric Smith
Our vacuum is losing suction, we think it's the vanes.
Where is the best outfit to order those?
10/28/15       #2: vanes for vacuum pump ...
Phill
Try Shroeder Equip Co in Denver, NC
704-489-6171
10/28/15       #3: vanes for vacuum pump ...
chip geffre
Eric-
I purchased new vanes for my pump thinking it was worn out. $900+ for my Becker. While waiting for delivery, I removed the rope gasket under my spoilboard and replaced it. The gasket had a bunch of dust that had collected and was compromising the seal. Blew it out and replaced the gasket and the pump works like new. Needless to say I was relieved to not have to replace the vanes! Best Regards!
11/2/15       #4: vanes for vacuum pump ...
Mike McClaran
Website: http://greenbvc.com
BVC can help. We have vanes as well as foam gasket. Remember it takes a few years for vanes to wear out. Also keep in mind vanes will blow up and shatter causing a loss of vacuum instantly. Good Luck.
909 606-0140
11/3/15       #5: vanes for vacuum pump ...
Matthew
Website: http://www.supervane.com
Try www.supervane.com
11/3/15       #6: vanes for vacuum pump ...
ERIC
My becker pump has a sticker on it showing what the measurement of the vanes minimum size is. If close to that get some on order because they will grenade!!!
